Question about Minolta EP1083 CS/PRO Copier
Ep1083 copier the top feeder does not feed
  • thedandavid Jan 05, 2009
    Does anybody want to buy one of these printers. I have a EP1083 and dont know if it works. It should have all its parts in tact, and I believe theres a full toner cartridge. I dont know how much this this is worth! email me at ddavid@chicagotech.com , my name is Dan and I'm located in chicago.
  • sam gerban
    sam gerban May 11, 2010
    need mor info .is it recognized by the main body?any error codes?
    Novelist:
  • 126 Answers
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Posted on Jan 05, 2009
SOURCE:
How do i get the feeder to stay up in the feed position. After it comes up it beeps and goes back down to the load position
The motor control board handle few sensor within the feeder. Check the cable telephone for proper connection. And at the very top of the feeder there is a sensor and one on the feeder itself at the bottom. If those sensor are good the problem could be the motor control board.
Jun 20, 2014 | Xante Ilumina Digital Color Press Printer
Error code C04 10
The bright light under the big glass is not working raise the doc feeder or the original cover and press the start button bright light should come on. if not replace the lamp and or the control board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 03, 2013 | Minolta EP1083 CS/PRO Copier
Please insert your originals into the automatic document feeder
Try holding the table top lid down gently while you feed it into the document feeder. It may be that it is not reading the top as closed to defer to the feeder.
Jan 02, 2012 | HP LaserJet 3055 All-In-One Printer
Help-the paper feeder does feed the paper so the amounts print on top of each other.
If the document feeder is not feeding paper properly, the first thing I would suspect is the feed rollers ( 2 or 3 in total,) as they have the tendency to become dirty and worn. My suggestion would be to open the document feeder, take a clean rag and some general cleaner (no solvent,) and wipe down each roller as best you can. This will act to remove any trapped dirt or debris in the feed roller traction marks, and thus give you a more reliable document feeder. However, if this fails to alleviate the issue and the rollers appear worn, replacing them would be your next step.
I would suggest precisionroller.com as a good source for printer, copier, and fax supplies.
-David.
Nov 05, 2010 | Office Equipment & Supplies
Will not feed original to copy from top insert level. Will copy if original is placed under, laid flat .
your feed tires for the document feeder are probaly needing replaceing. turn off mach and make sure document feeder plug is secure.
Dec 31, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Where is the auto feed for the copier. i have about 15 pages to copy and i do not know how to use the auto feed. thank you for your help
The question is that if the copier is equipped with an automatic document feeder or not. If you'll see on the top of your copier only a piece of plastic, most likely your copier don't have the feeder but if you see something far more complex, just put your paper there and press the Start button
Sep 03, 2009 | Panasonic FP-7735 Black and White Copier
PAPERS WONT FEED THRU TOP FEEDER
im having the same problem was working fine then quit feeding
Mar 31, 2009 | Minolta EP4000/5000 CS/PRO Copier
Ricoh Aficio 2022 not taking pages from the document feeder
check the feed tires to see if they are smooth at all. Sometimes they need to be replaced. There is a clutch as well in the feed mechanism that could be going out as well.
Nov 17, 2008 | Ricoh Aficio 2022 Black and White Copier
Gray background on all copies
When you tried adjusting the manual adjustment to lighter did it improve? If so, you may just have to clean the optics of the copier. It is easy to do. If you want to try it? Do you have a doc feeder? Turn the copier "off" and "unplug" it from the wall. Next open the doc feeder or cover for the copyboard glass. On the left side of the copyboard glass where you line up your orginals to the sive scale. There are " 2 " small #2 phil. size screws that hold it on " most of the time silver. Unscrew the 2 of them and left up the scale plate, CAREFULLY if you have a doc feeder there will be 1 or 2 spings there. Remove the spring and the copyboard glass. Next move the optics/ mirrors SLOWLY to the RIGHT side of the copier and with a dry and clean rag wipe the 3 mirrors of dirt CAREFULLY. Once you are satified they are clean return the copyboard glass and the 2 springs if remomed and return the scale and 2 screws. Then plug the copier back in and turn " on" the optics will go back to the Right postion by themself. Next make a copy and if it better you are done, if not you may need a new OPC drum & cln blade & a developer change to solve any C.Q. problem. Call a service company at that point.
Jan 26, 2008 | Minolta EP1083 CS/PRO Copier
Paper feeder
Check the paper fed tracks- make sure there are no debris in the channels. Can you hear the feed system working or is it not running?
Jun 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Open Questions:
See all Minolta EP1083 CS/PRO Copier Questions
295 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
