Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Wrong cartridge...I removed the cartridge head, cleaned with alcohol as suggested, to no avail
  • 823 Answers
If you are getting an error that says "wrong cartridge" then the ink cartridge you are trying to use is defective. Return the cartridge to the store you bought it at and get another one. Do not use refilled cartridges unless they are purchased by a professional who knows what they are doing. Your problem lies with your ink cartridge and not the printer.
Posted on Jul 16, 2011
SOURCE:
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
I keep getting a "wrong
Clean the print head/cartridge with Isopropol Alcohol (rubbing alcohol)and Q-Tips, The nozzles, the contacts and all the excess ink that had acummulated around the nozzles. The error message should clear.Run through all the maintenance checks and alignments. If this does not fix it, the print head needs to be replaced about $45-$60 from Canon.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 20, 2011 | Canon SmartBase MP730 All-In-One InkJet...
I suspect that the black printer head is clogged up, is that seomething that I can repair myself?
Hello
Yes you can repair by trying the following steps:-
Hope it helps, if so do rate the solution
good luck
Dec 27, 2010 | Brother MFC 7300C InkJet Printer
My printer won't print anything - only blank pages. However, both ink cartridges have ink. Please help!
If the self-cleaning cycle does not solve the problem, try turning the printer off overnight to allow the ink to soften. Turn the printer on the next day and try printing a test pattern to see whether the problem has either disappeared or become less noticeable. This ink-saving procedure can work effectively because sometimes the dried ink on the print head needs time to soften before the printer head can be cleaned completely. Try running the self-cleaning utility again one or more times.
Steps for Manually Cleaning the Printer Head
If the overnight cleaning still does not work, there may be a layer of thick ink that is blocking the holes of the printer's head. The next option is to manually clean the printer head. Follow these steps:
* Determine from the owner's manual where the print head is located.
* Remove the ink cartridge from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. NOTE: Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets, and if you get isopropyl alcohol on the gaskets it could dry them out.
* For models where the print head is in the printer, drop 7 to 10 drops of isopropyl alcohol (91% denatured isopropyl alcohol - not 'rubbing' alcohol) down the ink receptacle area where the ink actually flows from the cartridge into the head. Run a few self-cleaning utilities. If possible, allow the printer to sit a few hours or overnight and repeat the self-cleaning utility.
* If the print head is in the cartridge, soak the cartridge print head in hot water. Allow it to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
* If the hot water soak did not unclog the print head, place the cartridge printer head in isopropyl alcohol and allow it to soak overnight. Use a damp paper towel to wipe off the print head area and dry carefully. Try the self-cleaning utility again.
* If the alcohol soak did not unclog the print head in the cartridge you may need to purchase a new cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the printer head.
Jun 09, 2010 | HP DeskJet 5150 InkJet Printer
How to clean cartridge
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
  • Remove the tank.
  • Connect a hose directly on the inlet ink.
  • Locate the sensor of reservoir and press it to make as if a cartridge is available.
  • Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
  • Replace the tank up and do a test print.
  • Repeat the procedure several times if the nozzles are clogged.
Using a syringe and some alcohol to unblock the holes can also be very effective.
  • Step 1: Remove the cartridge from the computer
  • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
  • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
  • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
  • Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Apr 03, 2010 | Lexmark Inkjet Z517 Photo Printer
I cant print on my canon s200spx. the printer is working but nothing is printed. whats wrong?
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Mar 26, 2010 | Canon S200 InkJet Printer
My brother printer dcp-165C can't print black despite cleaning the printheads several times and changing the cartridge. what's wrong?
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
Hope this helps. .
Feb 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Full cartridges = empty :S
Solution 1
* Remove the tank.
* Connect a hose directly on the inlet ink.
* Locate the sensor of reservoir and press it to make as if a cartridge is available.
* Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
* Replace the tank up and do a test print.
* Repeat the procedure several times if the nozzles are clogged.
Solution 2
* Step 1: Remove the cartridge from the computer
* Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
* Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
* Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
* Step 5: Run some test prints before using the printer normally.
Jan 02, 2010 | Epson Stylus 880 InkJet Color Printer
Printing in wrong colors
You need to go to the maintenance tab on your printer properties and deep clean the head. If that fails, remove the print cartridges and poor some rubbing alcohol on the print head enough to wet it, replace cartridges and deep clean again, if that fails you may need a new print head or replace the printer, cost dependent.
Oct 08, 2009 | HP Photosmart 3310 Printer
Canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Oct 05, 2009 | Canon SmartBase MPC400 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
177 people viewed this question
Clive
Clive
old marine
old marine
