Tell it like it is Heat!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Heatman u need to stop posting that link. especially on every single question. the link is dead and you arent helping anyone by posting it.
to the OP, it is most likely sediment clog. while the tank is sucking in water, use your thumb and cover the left side of the intake valve so no water drains back into the tank. when it transitions to brewing, take your thumb off and let it drain into the tank. immediately after it stops brewing, again use your thumb and cover the left side of the intake while also removing the tank. this prevents the intake from taking in all the sediment that just drained into the tank. now rinse out the tank, fill it up just above the black level indicator (about 1/4 full), then keep repeating this process until no sediment can be seen in the tank when you hold it up to light.
As you can see my last response to this was almost a year ago....the link is inactive because of FixYa's refusal to pay me for tips as was agreed when originally posted...this site is going to the dog's because of new management that is running it into the ground....no longer very active here anymore...if anyone wants the tip they can email me a [email protected] and I will be more then happy to email it to them directly.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
