Plug in one a at time using the same input. Take the left speaker and the left input wire. Plug the wire from the mixer into the one speaker if it sounds ok then unplug the speaker and replace it with the right speaker. If it sounds ok replace the wire with the right wire. This will tell you that each speaker is working and each cable is working. If you switch speakers and they sound different then the possibility of a blown high end driver in one. If they sound ok each by it self but the high end suffers when they are both hooked up then the possibility of the speakers might be. Not sure what the sub has to do with the whold setup. Any further questions call me at the store. Vito Vacirca Jr. Pro Line Music 490 Lincoln Highway Fairless Hills Pa. 19030 215-736-8055
