Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
in order to listen and watch your magnavox
DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to
Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other
..pls remember,Always reverse connected ) (audio will come thru
Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on magnavox
you need to connect "Audio Output " as can either be : RCA jacks or
"Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has
different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input" of your magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue for Helping out the Community :)
