For about a week now the coffee maker starts and will brew about 8 cups out of tweleve, then stop and the burner stays on for a few minutes and then shuts off. If you go back a few minutes later and turn it back on it will brew the rest of the water. Then the keep warm shuts down too. Trying to turn the warmer back on fails. No light comes on.
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
I have the same problem as above, brews 8 to 10 cups out of 12 and shuts itself off. If you set the coffee maker to auto on, the entire cycle will brew completely? I have cleaned it as instructed in the manual and as used the cleaning procedures given on your call in line. Still will not brew a complete pot of coffee in the manual brew cycle.
my coffeemaker brews half of the water than stops and shuts itself off. thisis a new machine and the problem occurred even when i was running through only water without coffee.
Same issue here
Brews about 4 cups and then stops and the light turns off. It knows it's not done because it doesn't beep. If you toggle the switch on again it will usually complete the brewing and then it will beep.
