RCA D52W19 52" Rear Projection Television Logo
Posted on Jul 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER BUTTON 3 TIMES
TV Doctor
Level 3:
  • Master 373 Answers
  • Posted on Jul 15, 2011
TV Doctor
Master
Level 3:
Answers
373
Questions
Helped
92971
Points
1011
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Testimonial: "YES SIR YOU ARE RIGHT YEAH THANKS FOR ALL THE HELP"
Chris Spurlock
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 05, 2013
Chris Spurlock
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1123
Points
IT'S FLYBACK MODEL 259296. Let me know if it works. This Flyback is for RCA D52W19 AND ABOUT 50 OTHER MODELS.
  • Chris Spurlock Jun 05, 2013
    $64.95
  • andrewger350 Nov 27, 2014
Rca tv d52w19 shuts-off
hello,
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.
use the same type of value to replace.
Good luck...
3helpful
Tv doesnt work
CK capacitor cp150 on deflection board if it is puffed up on top it is Bad 2200uf 16v use 25v other 2 caps in same circuit need to be replaced also cp114 cp120 220uf 35v
TV will not power on. Button slowly flashes green several times
CP120, CP114 and CP150 need replacement. You can get replacements at the following link under the RCA parts catagory.
http://servicemanuals.vstore.ca/
RCA D52W19 "crackles" and smells like its burning
Hello pmzone_guard, This problem is quite common in this TV it's due to a capacitor in the power supply being overloaded. The chassis model is a ITC222. The capacitor is located on the deflection board which is part of the power supply and should not be touch by someone that does not have TV Repair Experience, due to the fact that this area of the TV is the most dangerous. I would suggest having a qualified TV repair technician do the repair on this TV. If the problem is just that one capacitor the part will cost about $2.50 at the most, so the charge will be the cost of the part plus the labor involved. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
2helpful
Rca d52w19 push power flashes 3 times and makes buzz each time
Check capacitors cp150,cp114,cp120 if any of the capacitors are puffed up on top replace all 3 of them 2200uf 16v and (2) 220uf 35v
Rca D52W19
I would try replacing CP150 , CP114 and also CP120 as those three capacitors have been known too fail which will prevent the set from powering up.
Rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
1helpful
3answers
Does nt turn on
I tried the flyback 259296 and that did not work. I changed the cp150 and my tv works like new. CP150 cost me $2. Flyback 259296 cost me $60 for nothing
3 green blinks
Look on Deflection board cp 150 2200uf 16v capacitor and there is 2 more capacitors 220uf 35v replace both of them. Green and Gold writing on caps.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
