If you have computer handy type words on screen into Google translate and that should solve your problem
Hello Swetha.
Can you do a screen-scan on a flatbed scanner of a page showing the language?
Then the word equivalents can be looked up to help you navigate.
Otherwise post a few of the words which may give us 'le clue'...
SOURCE: language is in russian ,need to change to english,help,help
it should have the english anyway. try do an soft-reset *#7370# it will restore the phone settings to factory settings.
SOURCE: Nokia N70 Lost language Features After SW Upgrading
(First: copy all contacts from the phone to SIM card)
1.Switch off the phone.
2. Press and hold the following three buttons:
Green(call answer) button, (*) button, (3) button.
3.Now press the switch on button.
4.Then the message 'Formatting" appears on the screen release all buttons. I hope this can assist you in the fix .
SOURCE: Hello i use nokia 5130 xpress music by mistake i
just press *#7370# and enter 12345 for default code
becareful it erase u'r data back to factory mode
SOURCE: How can I change the phone language on my Nokia 5000?
dude this happened to me 1ce.........first find a frnd or sum1 who has the same phone(wit english).......then use his\her menu to help u navigate....the crotian system is the same as the english 1 so all u gotta do is match it.....this worked for me..........if not u will hav to use the google translator to fix ur prob..
HOPE THAT HELPED....:D
