SOURCE: Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
SOURCE: orange light
The orange light is for you to know that the plastation2 is working unless it is not reading the disk then you etheir take it back or tip it over on its side then let it do the rest or if that dont work then it either broke or if you get it to work then you are alright at games.................. thats all the info i have on that........ there you go.
SOURCE: Temperature indicator turns on in my Epson EMP-500
it appears that one of the cooling fans in ur projector is jammed or not spinning at the required speed!
ope the projector & observe the fans as u switch on!!!if the fans seem fine, then it could be a defective thermistor!
SOURCE: My Viewsonic PJ458D lamp not coming on
I have the same problem before. I found a replacement fan. A computer chassis fan works perfect. It should be 60mmx60mm - plenty in E-bay for about $5.00. Very easy to open the unit to replace the fan. It has 2 fans in a rubber housing. Check which one need replacement.
SOURCE: Good morning, I was given
I have exactly same problem with my brand new tomtom 540tm. it is in "sleep mode' but how to wake it up?
