Expert
- Posted on Jul 15, 2011
Re: My problem is i have all yellow ports flashing in 10...
- Using a Null-Modem Cable , hook up the Console port of the switch to an available COM port on a computer (cable must be able
to provide serial port communication between 2 computers).
- Set up a Hyperterminal session to that COM port (e.g.: com1), with
the port settings at 9600/8/N/1/N (. When the screen comes
up blank with a blinking cursor, hit [enter] once or twice to bring up a
login prompt.
- Alternative to 1 and 2 above, if there is a known assigned TCP/IP
address for the switch, one can telnet to that address, hit
[enter] once or twice to get the login prompt.
- Default logins to try are admin/(no password) or security/security. One of those 2 should bring up the management menu.
- To reset factory defaults, type SYSTEM[enter] then type
INITIALIZE[enter]. This will reset everything that has been set up on
the switch, with the exception of the TCP/IP address, if there is one.
All other previous configurations will need to be
re-entered.
- You can type in username "3comcso" and password "RIP000". It will ask you to reinitialize the switch.
This will reset all settings including passwords.
