Posted on Jul 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Anonymous
Level 2:
Scholar:
  • Expert 30 Answers
  • Posted on Jul 15, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
30
Questions
0
Helped
11673
Points
104
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
MobileJB
I have a Behringer PMP 6000 that I just bought. With the power amp switch in Main L/Main R it works fine, but if I switch it to Main/Mon, only the Mon works, nothing from the Main. Bridge mode doesn't...
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
I have 2 dead channels - what could the problem be?
The faders could be dirty. Spray a small amount of professional electronic cleaner into the fader and work it back and forth. This may or may not fix the problem.
1helpful
Half the signal only through left speaker
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Where are the amps and how do i by pass them for the stereo
The amps are located inside the radio. Most in-dash receivers that provide for "pre-amp outputs" also called "low level outputs" do so by providing female RCA type jacks. These are often found at the end of a short (4 - 6 inch) cable and are usually color coded red & white or red & black (some receivers provide a yellow RCA jack for video in / out, too). To use these RCA audio jacks, you need to realize that one jack is for the left channel source and the other is for the right channel source for a stereo signal. You will have to connect a compatible plug and cable of enough length to extend to a remote amplifier's RCA input jacks. The vehicle's speakers would also need to be connected directly to the same amplifier's output terminals. Using the two audio (left and right) RCA jacks will only allow the radio to control balance of the left and right audio, no fader (front and rear) control is possible. To get fader control, you'd have to either have a radio with four RCA low level output jacks (front L & R *and* rear L & R), or use the radio's speaker (or high level output) wires and connect them to the amplifier's speaker (or high level) input terminals.
All unused receiver wires should be terminated in a wirenut or securely wrapped in electrical tape to prevent accidental contact with grounded metal or other wires behind the dash.
I hope this helps!
1helpful
2answers
Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
4answers
White noise in left channel on my Vestax PMC 06 pro-a DJ mixer
try it with nothing plugged in to the inputs, if there is no noise. most likely its the turntable, cd player, or whatever the input is is the problem. or try plugging the mixer into a different area of the house/room. its like if you were to put your cell phone by a mixer, or speakers.
1 X 1200Mk2deck higher volume / causing spkr not to work..
Problem If you swapped the two TT's would the problem stay with the connection on your mixer? At least then you/we would know wherein lies the problem. I'm betting thge low volume is because you have the phono jacked into a line level input like AUX instead of PHONO.
Typically, what you're describing is a phone source plugged into a NON-phono connection. (Tinny, low volume - classic lack of a phono preamplifier with RIAA equaliztion). A standard old-school tuntable requires a phono preamp that is labeled "PHONO". Nothing else will give it the boost and freq response correction LP's and phono cartridges produce.
Your problem #2 alludes to a channel problem with a turntable running through your mixer. This isn't rocket science. Swapping the two turntable channels around would probably change the apparent failing channel, right? Yes - Problem out at the turntable. No - problem in the mixer. You've already hinted at the source by monkeying with the tonearm wiring. You're on the right track. The tiny multi-colored wires in the cartridge shell are very thin and delicate. Their brass fittings sometimes oxidize and reseating them as you have done usually gives some relief. Kinks in the wires could cause your intermittent symptom. At the RCA end of the tonearm cables, make sure they're seated on with a twist to wipe off oxide.
Problem #3. Is it just bothering you or is there a functional problem, too?
Vestax o5 pro mixer channel 2 not working
Doe you get sound in from the headphones? If so, then the issue might be the volume fader for that specific channel.
If not, then the issue might be the input connections or input pc board the connections are soldered on to.
The fader can be self replaced, although complete disassembly of your unit is required. Not a hard task, but there are alot of jumper cables, and you have to be careful when putting her back together.
If it's the latter, then I would suggest taking it to a service center for repair.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
1helpful
2answers
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
 Grubhead
Grubhead
SmartAviator
SmartAviator
