SOURCE: No Video or Sound - Red Stand By Light Blinks 6 Times
My book that i have with my tv says it is time to have it servicedby adealer sorry thats all it says
SOURCE: stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
SOURCE: tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
SOURCE: my television goes directly to stand by when I
Unfortunately, what you're describing is a repair issue. You won't be
able to address the problem with troubleshooting. There is a part
inside the TV that needs to be replaced. If you're under warranty,
this will cost you nothing. If you're not under warranty the cost
will likely be a minimum of $200 parts and labor. However, be warned
that the cost could be considerably higher. You should call the
manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further
SOURCE: 32' Sony won't turn on
Hello Marcappraisa the code that your tv set is giving you means that your tv set is having a problem in the horizontal circuit which is causing your tv set to act this way, this problem could be caused by different components in that circuit such as a capcitor or the junghle IC in that circuit, what i would suggest is to have a tech come out and service your tv set and let you know how much is the repair going to be, thank you very much for using fixya and i am pretty sure that your problem is coming from the horizontal high voltage circuit thank you again.
