Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I own a D-Link wireless router (Model WBR 1310), and am having connectivity issues. The WAN light [the one that shows if its sending out a signal] is blinking continuously. My connection to the internet seems pretty hit or miss, like its not a continuous signal. I've had this router for close to 4 years now with no problems, as this is the first real issue I've had with it. Any ideas?
    Top Expert:
  • D-Link Master
  • 54,386 Answers
The fault may lie with your provider. My router is having issues currently.
Posted on Aug 13, 2017
6ya staff
SOURCE:
Cloudbooks
  • 163 Answers
SOURCE: free download of d-link wbr-1310
just click below link and select your country code you can download
the installation guide for free
http://support.dlink.com/products/revision.asp
Posted on Dec 18, 2008
Anonymous
SOURCE: D-Link Wireless Router WBR-1310, Version A1
I had the same problem.
Make sure you turn off all the security with the software in package then slowly turn it all back on, on piece at a time. For whatever reason, it comes with MAC address filtering already turned on, which makes it impossible to see if you don't have the right info put in to the computer that the router was configured with.
Posted on Feb 27, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: D-LINK WBR 1310 ROUTER
Go the router setup page, 192.168.0.1, type admin as the user name and password as the password (default, if you have changed these use your login info).
Then on the wireless page change the SSID (router name).
You can also add a security key on this page.
http://support.dlink.com/emulators/wbr1310_revA/wireless.htm
more info from D-Link:
http://www.dlink.com/products/support.asp?pid=474&pv=96&sec=1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 12, 2009
garethmt
Gareth Tomlinson
  • 116 Answers
SOURCE: No connection
No, it sounds like your authentication or encryption is wrong. Authentication should be "open" encryption can be WEP, WPA or WPA2, and can be in alphanumeric characters (ASCII) or restricted alphanumeric (HEX) with numbers 0 to 9 and letters A to F only.
Are you able to detect the wireless network broadcast? (SSID). Are you able to get a wireless connection AND a legitimate IP address? Try tunning "ipconfig" from a command prompt, your IP should NOT be 169.254.(anything).
Posted on Jun 01, 2009
Anonymous
  • 56 Answers
SOURCE: how to install d link WBR 310
Go here and get the infor needed, guides etc....
http://www.dlink.com.ph/support/supportdl.asp?pid=602
Posted on Sep 16, 2009
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
My wireless light on my router keeps blinking, it will not send out a wireless signal either... I can connect wired throught the desktop but that is all
Try to check the configuration setting of your wireless router. There must be a problem in one of its configuration settings causes it not to send out wireless signals.
Nov 02, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have just installed my router and now the WAN light is flashing green...even thoguh there are no computers turned on. Is this normal?
Yes it is.
Its an indication that the router is working fine and that it is broadcasting wireless signal.
Don't forget to rate this answer if it helps
Sep 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Lap top WI-FI does not work with this WBR-1310...no signal showing connections...however, did work a few days ago. Using HP laptop Pavilion.
Make sure you didn't accidentally hit or tap the wireless button as that shuts off all internet connecting abilities.
Apr 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I HAVE A DLINK WBR-1310 ROUTER WHERE DOES THE BLUW
Hi!
You can use any UTP cables. Here is how the connection would look like:
DSL -> DLINK WAN PORT
DLINK PORT 1(or any other ports) <---> COMPUTER
If the router is set to give out IP addresses automatically(DHCP), you should be able to connect flawlessly.
Oct 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link Wireless Router WBR-1310 wont connect?
- Check LAN cable
- Use a different cable
- Use "crossed" LAN cable
Oct 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
WBR-1310. No admin logon, only f/w upgrade page
Download firmware from site
http://www.dlink.com/products/?tab=1&pid=WBR-1310&rev=WBR-1310
DLink states the login issue has been fixed with firmware v1.04 3/28/07
Remember to get the right one for your unit model. You must connect a RJ45 cable to the router and computer you have downloaded the firmware to and remember which directory it's in. When it asks for the firmware put in the target location (c:\my documents\xxxxx) of the firmware file. Good luck.
Jul 02, 2009 | D-Link 802.11g Wireless Router WBR-1310...
No connection
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have a d-link wbr-1310 ver:d1 f/w:4.00 no signal
reset your router wait 20 sec re-boot
go to your wirless pc / or lap top and see if you can see this product
if not you may issues that can not be fixed remotly
Apr 26, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
136 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
