What is the differance between utility pump and solid pump?
Utility Pumps: Utility pumps draw water through openings that screen out debris. When placing one into a pond, use a pump sock or other enclosure to reduce the amount of cleaning needed. If you use a pump sock, be aware that sock-like screening can cause a dry pump situation. Solids Pumps: These pumps draw water through a large opening and pump small debris through without clogging. For this reason, they can be placed into a pond without prefilters. Note, however, that this type is not safe for ponds with fish, frogs or other aquatic animals
