Question about Cooper Industries Weller Soldering Iron, Slim, for WES51, Uses Eta Tips
Soldering iron troubleshooting
Are there different types of bits?
  • Anonymous Apr 20, 2009
    cannot use cooper
    President:
  • 2,712 Answers
Bits: It's useful to have a small selection of manufacturer's bits (soldering iron tips) available with different diameters or shapes, which can be changed depending on the type of work in hand. You'll probably find that you become accustomed to, and work best with, a particular shape of tip. Often, tips are iron-coated to preserve their life, or they may be bright-plated instead. Copper tips are seldom seen these days.
Posted on Aug 27, 2008
SOURCE:
How to make my soldering iron melt solder fast
get a lower melting point solder
get a higher temp tip if so equiped
get a higher wattage iron.
Jul 28, 2014 | Welding Tools
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
Broken switch
Hi
which switch is broken?
Do you mean the power switch?
If so, a technician should repair it.
Please tell us your results
Good Luck
May 13, 2011 | Fujitsu LIFEBOOK N6110 PC Notebook
I have a weller wp35, 35 watt iron. It came with the ST3 tip. I want to solder automotive wire, Say 14 to 20 gauge wire. Two questions: 1 is the wp35 strong/hot enough to do this type of soldering? 2...
The WP35 is strong enough and the ST3 tip will do the job. The larger tips are really only for covering larger items but when soldering it's the wire you heat, rather than the solder, and melt the solder with the wire. The tip will reach the same temperature regardless of the size and while the larger tip might heat the wire a little faster the difference would not even be noticeable.
Jan 30, 2011 | Welding Tools
I have two WU81 Weller soldering irons and their are both showing the same fault. When we turn the irons on in the morning, the 500mA fuse that can be found in the base unit is blowing. Is this a common...
Perhaps this fuse should be a "T" type or delayed acting (antisurge fuse) . If the fuse has been replaced by an "F" fast acting fuse then this could explain why they are blowing.
Aug 10, 2010 | Cooper Industries Weller Soldering Iron,...
Iron is not heating up hot enough stained glass soldering iron:
hi friend,
check this out
Consider the wattage of the soldering iron. A good soldering iron will have wattage of 80 to 150. A wattage of lower than 80 is not ideal for stained glass. You need a soldering iron that will melt the solder fast enough for your project. Consider the type of temperature control you want. Some irons will have a temperature control built in the tip. When the temperature drops, it will turn on and when the temperature is reached, it will turn off. Other soldering irons have a built-in rheostat. You control the temperature by turning the dial up or down. A separate rheostat can be purchased to plug your soldiering iron into. Rheostats are highly recommended. This lets you match your temperature to your soldering style and allow you to do decorative effects.
  • Step 2 Consider the heating element. There are two types of elements, ceramic or wire-wrapped. Ceramic core irons maintain heat more efficiently than wound wire heaters. In a ceramic core, the heater core extends into the tip for faster heat transfer. This will keep the tip hot for a longer period so you can work quickly and faster. Ceramic irons maintain their temperature longer and heat up within 30 to 60 seconds.
  • Step 3 Consider the weight of the soldering iron. You want a soldering iron that is lightweight and balanced. You will have less fatigue when using a lightweight soldering iron at long stretches of time. Check to see if it fits your hand comfortably. Check to see if it has a good rubber cushion for your hand.
  • Step 4 Check for the ease of changing tips on your soldering iron. When soldering stained glass, you want to match your tip to the technique you want to use. There are a variety of tips on the market for soldering irons, and you want to be able to change them easily.
  • Step 5 Check the soldering iron to see if it has a heavy-duty cord and a three-prong plug. You want a grounded three-prong plug to prevent the possibility of shock.
  • hope this helps u
    please rate me......................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Weller Welding Tools
    What type of solder is the best to usefor the weller pro soldering tool cht100
    It's not the solder you use for the soldering tool but the correct solder for the JOB you are doing with the tool.
    Read the packages and pick the right mix/flux/thickness etc for the metal/connectors/etc you are soldering.
    Aug 17, 2009 | Cooper Industries Weller Kit, Super Pro...
    What are the parts of a soldering iron?
    we have: soldering element, the bit ( can be iron or cooper), handle , and the wire
    Jul 05, 2009 | Welding Tools
    Tips are corroding & disappearing
    That is normal for a soldering gun especially if you are using acid core solder. I do a lot of soldering with rosin core & have to change the tip about every 6-8 months. Just get a couple of new tips. Rick
    Mar 06, 2009 | Black & Decker Black Decker Dualtemp...
    Cooper Industries Weller Soldering Iron, Slim, for WES51, Uses Eta Tips Logo
    558 people viewed this question
    Top Cooper Welding Tools Experts
    David Soto
    David Soto
    Bill Boyd
    Are you a Cooper Welding Tool Expert? Answer questions, earn points and help others
