Try to increase the psi to 125,if possible.also clean the air tool out with wd 40 and or auto trans.fluid.Try this and put it in the end of gun where the air goes in at.
get some air tool oil and oil it lol, if that will not speed it
back up you may have to take it apart and clean it but the oil should
do the trick. Do NOT use wd40, etc. use air tool oil
Normally when the air will not drive the tool, it is because 1- the tool is rusted up inside, 2- there is no lubrication of the moving parts - which can be remedied by putting something like WD40 in the inlet with the air switch open, 3- the drive parts are broken or worn out, 4- not enough air volume/pressure to run the sander.
You probably need to spray some lube as above & see if that will get it to work. Also turn the sander part by hand. Rick
* Proper match between air compressor and tool ratings.
* Correct fittings that match the tool and air hose.
* Well-maintained air compressor and air hose.
* Correct air pressure adjustment for the tool being used.
You can add different sanding discs to an orbital air sander to ensure that it is properly set up for a huge variety of different jobs. From heavy duty sanding paper for tough jobs through to buffing cloths in order to get a final polished finish at the end of the job. With most orbital air sanders, changing the disc takes just a few seconds, allowing you to get a variety of jobs done a lot quicker.
