In line oiler Lubrication is critical to extending the life of your valuable air impact wrench and increase productivity. An air tool that has not been properly lubricated will result in low power output. The usual culprit is a dry motor starving for some oil. Your impact wrench is an expensive investment and you must take the time to properly lubricate it. The easiest and quickest way to make surein line oiler it is constantly lubricated is to install an in line oil lubricator. One of these will insure your air tools are receiving oil every time they are used. In line lubricators attach right into the air hose and you fill them with the correct lubricating oil. (see your manufacturer's specs.). You should also do routine external lubrication through the hammer case grease fitting. A well lubricated air impact wrench will deliver more torque, last longer, run quieter and increase productivity. Don't forget to add an in line oiler to your next impact wrench or air tool. It will pay for itself several times over.
