Re: It will not turn on, took it to a Radio Shack just...
Probably
a burned out fuse on the power cord. Unscrew the end of the 12v plug
and check the fuse with an OHM meter or just replace the fuse. Check
that you have 12volts at the gps end of the cord.
I have an ilder infiniti qx 4 with this stereo and had problums with the volume nob as I am fairly technical and the radio was not working well anyway whats the worst that could happen so I removed the radio and took out the circuit board with the nob on it and got some contact cleaner from radio shack sprayed the nob while turning it back and forth put it all back together and it works great it took a bit of time but I had more time then money
I will fix it by returning the item to
Radio Shack. Do not think much ofhe service. Some guy like me makes a suggestion and then you try to up sell to another product.
I took mine to Radio Shack, because of that same problem. The guy there said that the battery card was not all of the way pushed in. Also, Radio Shack had sold me a 4G memory card to go with it and he, a different guy from Radio Shack, said that that was too much. It does work with my 1G card and he said it might work with a 2G. Who knows. With the battery pushed in correctly, it might work with the 4G.
I have no book, users guide. A girl a the store accidentally cut in half when she opened the package for me. No, she did not give me a new book! Yes, I asked.
My first guess would be to take a volt meter, and check the power pack to see if it's putting out the correct DC voltage(or any voltage). Those things are super cheap! Then check the plug in on the scanner to make sure your getting a good connection(might have a broken connection to the circuit board). If those are 2 year old rechargeable batteries, they might be getting close to laying down and dying. Hope this helps,, Mechanic
