SOme web browser have filtering the internet. Try the current internet explorer or firefox. im assume that you are using Firefox right? For many time you can access with right username and password. But one day, you can'nt login even with true and right 100% username and password. What you get is access denied page.
If you still face this problem, try log on using safe mode and using internet explorer to browse the account. Good luck my dear
Ensure you typed in your correct username and password, then if it denies you the access, then it will require you to fill in some answers to some security check questions, answer them correctly and it will log in.
If it says incorrect password or username, try to access it from any that is sent to your inbox, then if it does not access it still, then it is either facebook is experiencing a temporary problem or that your password have been changed or your account have been tampered with.
First make sure the Internet is working.
If it is then try to login with the same username and password on www.hotmail.com if you can log in then it's a problem with outlook express if you cant then that is the problem.
To make sure outlook express is correct click on Tools, Accounts then click on Mail tab and then click on your email address and select properties make sure the username and password are correct or retype them.
check the permission of the share and also you may have to create a user just for sharing
This is a permission issue. If the net view command fails with a "System error 5 has occurred. Access is denied." message, 1) make sure you are logged on using an account that has permission to view the shares on the remote computer. 2) Need to cache credential: logon the same username and password on both computers or use net net use \\computername /user:username command. 3) Make sure the Netlogon service is running
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
i assume you can enter the correct username and password.
if not and you don't have any idea what the password could be other than standard ones like 1234, 0000, admin you got to reset your router.
if you do know your password and username you probably have a high internet security settings and/or problems with accepting cookies. Try adding the address 192.168.2.1 to safe websites in your internet explorer settings.
