SOURCE: my hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
