Question about Yamaha RX-V2090 Receiver
Intermittant issue for a while now...power on with remote or button on front panel, it will light for just a moment (very few seconds) and then shut off. At the moment, it's in the mode of NOT turning on other than the second or two once the power button is pressed. HAD been working normally until a few days ago.
    Brigadier General:
  • 8,546 Answers
Death throes will become permanent the more it is stressed.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jul 14, 2011
SOURCE:
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Locked TV have no remote, tv won't turn on
You're going to need the remote to fix this one. If you have any other GE or RCA tv's you can try it. Most of the remotes that are produced within a few years of your television will probably work. When you get one the instructions are: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
Sony Tv 42" projection tv will not turn with remote or button on front standby light blinks 9 times pauses then another 9 times. When this started we use to be able to continually hit the power button and...
The 9 flash error usually means an issue with one of the power supply boards in the TV. You can verify this by bypassing the shutdown. To do this with the set off and in the standby mode point the Sony remote at the TV and press these buttons in sequence within 5 seconds of each other, DISPLAY 5 VOLUME DOWN and then POWER. The set should turn on with no issues. Once it comes on there will be a diagnosis screen and the bottom entry on the screen should be ZCD. That entry should have a zero in the fail column. If it has anything besides zero then the power supply board is at fault. There are two power boards in this TV so I don't remember which one causes the issue whether its the G1 or G2 board. At this point if this is the issue then I would have a technician do the repair since replacing either board isn't that easy. Please take a few moments to rate my answer. Thank you....
Nov 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Yamaha RX-V2090 Receiver Logo
78 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
