Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
Viking dishwasher won't drain. - Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
  • trailside83 Jul 14, 2011
    it seems that the pump is functioning okay, all drain hoses are clear. When I turn the timer (right knob) to any setting the pump is switched on and will not turn off at any setting. Is this a timer problem? Please advise. trailside83
    It does seem to be a timer issue... one more problem. the model/serial number sticker on edge of door is torn badly so I can not identify the exact model number to order the timer online. Is there another place that I can find the model number. The washer came with the house and no manuals. thanks in advance. trailside83
    New Friend:
Check the easy stuff first. My solution was to clear the Anti-Siphon valve that is easily accessible on the top of the sink. After I verified my filters were clean and the pump was working I found the clogged anti-siphon valve. Cleared that and my dishwasher worked just fine. Lift the decorative cover off and mine had two small tabs to remove a cap. I found peanuts and a match head inside. Who knows how they got there. To be sure I had everything I removed the hoses under the sink and then removed the whole valve and carefully cleaned it. I'm not sure that was necessary though. Hope this helps
http://www.kimmellinspectionservices.com/2007/09/25/anti-siphon-valves-air-gaps/
Posted on Sep 21, 2015
  • 10,515 Answers
You either have a faulty drain pump motor..Or there is some blockage at the pump to drain hose area....Remove the front bottom kick plate....Set the washer to drain...See if you can hear the pump humming ..If so you will need to remove the hose from the drain pump...Be careful o the amount of water that will come out...Best thing to do is use a shop vac to empty the inside drum...Then use again underneath once you carefully remove the hose. Pump is easily accessed once you take off the bottom panels, so do that and investigate as needed to see what is really wrong. There is no secret to taking off the bottom panels-all screws are clearly visible.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 13, 2011
  • taran_2005
    taran_2005 Jul 14, 2011
    Thanks for your response!!
    If you have already excluded pump and hose, not being the case here - next two probabilities would be timer and control board.The most common problem is the timer going bad. As long as it works good
    and advances through the cycles and just hangs up when it comes to
    draining the water then I would say you have a bad timer.
    Thanks and Regards
    taran_2005
  • taran_2005
    Without the model number, it would be really tough to find the exact timer. However, ideally model numbers are printer more often in multiple locations. Look at the below link and see, if you could find the model number engrossed anywhere else on the machine :-
    http://www.partselect.com/model-number-l...
    Above is a generic picture.
    Thanks and Regards
    taran_2005
6ya staff
SOURCE:
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
Aug 10, 2012 | Viking DFUD142 Built-in Dishwasher
Dishwasher doesn't drain completely and then turns itself off. Dishes are not clean.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 12, 2011 | Viking DFUD042 Built-in Dishwasher
My viking dishwasher won't complete it's cycle. The error code that flashes is the heavy pots and pans. We've checked the filter and drains and nothing is clogged. What else could it be?
Have you checked the kitchen sink drain and air gap if one is installed in your kitchen. If using the garbage disposal unit in kitchen then make sure it is clear.
provide model number of dishwasher for further diagnosis.
Aug 28, 2011 | Dishwashers
My Viking DFUD042 is stuck in drain cycle while fresh water is entering the dishwasher through the grid on the right side. The pump is working continuously and it only stops after I turn off the power. ...
Hi, this could be a bad control board or a bad motor. It uses the same motor to wash as to drain. It just changes the direction of the motor in order to switch from drain to wash.
You'll need to run a cycle and you will need a multimeter to check which one needs to be replaced. Remove the kick panel and check the grey wire to the ground wire when it should be washing. If you have 120 volts, you need to order and replace your control board. Otherwise, if you don't have power and it's still draining, you need to order and replace the motor.
Jun 23, 2011 | Viking DFUD042 Built-in Dishwasher
The dishwasher doesn't seem to drain water.
heatman101
May 10, 2011 | Viking DFUD04 Built-in Dishwasher
My dishwasher won't pump out. I've cleaned filter and cleared line. still won't pump
heatman101
May 09, 2011 | Maytag Dishwashers
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
3,538 people viewed this question
Top Viking Dishwashers Experts
Ekse
Pierre Laplante
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
