Kyocera CS-4035 Copier Logo
Posted on Jul 13, 2011
What type of corona wire is used on Kyocera products: FS-9520, KM-4035, KM-3530, and KM-C2520. Is it 60 Micron Oxidized?
LD1908
Level 1:
Habit-Forming:
New Friend:
  • Contributor 28 Answers
  • Posted on Jul 14, 2011
LD1908
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
28
Questions
0
Helped
41696
Points
58
The service manual does not specify but you will probably be ok with tungsten or oxidized. If the copies look bad with one try the other. The main charge is replaced as a whole charge assembly so I can't say that I have had to restring one.
Copies black
It sounds as if the Main Corona unit is shorting out. This normally happens when you replace the toner cartridge. Please try cleaning the main corona wire.(instructions in the box)
I have a kyocera km 3035 printer and it started printing solid black pages
You may clear the problem by cleaning the primary corona wire inside the drum unit by sliding the blue tab.Make sure you return the blue tab to the Home position.
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
RESET A KM FS 9520?
The self-diagnostic function maybe able to be reset by opening and closing the front cover or by turning the machine on and off. If unable to reset the error after trying both of the previously mentioned ways call us to place a service call or place one On-line.
further assistance please fill out a Technical Support Request Form. In most cases, support questions will be addressed within 24 hours of receipt.
http://www.gfbm.net/request_technical_support_form.htm
*The Technical Support Request Form should not be used for mechanical problems with your machine. You should use the Request Service page for mechanical problems.
You can also contact the manufacturer directly for Technical Support. Kyocera Mita (800) 438-6482
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
My kyocera FS-C5015N printer is printing all my pages with blue background, also get alot of paper jams
Reclean the cyan corona wire/grid with the cleaning block that comes with each toner.ensure that you leave the corona unit as far out of the machine as possible for 30 seconds to allow the grid to dry.If this does not work then you will need a technician to attend to the printer.
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
2answers
Kyocera fs 1750
First check the neck of the bottle and clean it if dirty
secondly if this does not cure the fault then the sensor in the drum assembly is probably dirty. You will ether have to strip off the end of the drum and clean the led and photo sensor or replace the drum unit.
55helpful
3answers
Have error: C6000 on Kyocera KM-3050
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
