Televison & Video Logo
Posted on Jul 13, 2011
Toshiba Color Television 36A43 Lost the original remote and purchased a universal remote. Tried to program using all four systems to no avail. I require the universal remote code to program for this TV
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Jul 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
Helped
1509
Points
19
Place one remote on table, place other (new) remote facing old remote, then push the program button on new remote, remotes IR screens has to face each other to make this work. and if you've tried to program the new one before, you will have to clear the new ones memory first. Good luck.
I have a RCA television model # L40FHD41YX9. I lost the original remote and have bought four different universal remotes but none of them will program to my television. How can I fix this problem.
You can order a remote directly from RCA but they are really expensive. The largest database of online remote codes I know of is Logitech Harmony. I would buy a Harmony Universal Remote.
Cheers,
Kevin
I lost my remote for a Toshiba BDX2000KU Blu-Ray player. I bought a Universal Remote and I can't program it using any of the codes or manual setup.
http://www.partstore.com/Part/Toshiba/Toshiba/BDX2000KU/Toshiba/Toshiba/79104846/New.aspx
Partstore has the original remote for purchase at the link above.
Lost original remote. need to find replacement.tried programing direct t.v.remote,but it wouldnt accept any of the codes given. I tried manually according to directions, but after hundreds of clicks it...
If you can't get the direct tv to work with your television universally you may need to purchase a remote that will control this television.
http://www.replacementremotes.com/store/prodthumbs.cfm?ns=1&keyword=dtq27u4sc&category=
2answers
We don't have a remote for the tv-vcr the model is mv13l3
The remote is listed as in stock here: http://www.searspartsdirect.com/partsdirect/part-number/Toshiba-Parts/Television-Parts/BZ614201/0057/528/Model-MV13L3/1100/0333300?keySuffixId=NA&productTypeId=x&searchModelNumber=MV13L3&subCompDesc=Cabinet%20parts&brandDesc=TOSHIBA&modelDesc=COLOR-TV/VCR&blt=11 . Remotes.com also has the original remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=MV13L3&uuid=12990337541060 .
There are also many universal remotes that will work. Just make sure to research and make sure you select a model that has codes for combination TV/VCR units. Many manuals and code lists are available online from their manufacturer. There are some remotes that do not handle combination units.
RCA remote documentation is available here: http://www.rcaaudiovideo.com/ . One for All remotes have their documentation here: http://www.oneforall.com/ .
I hope this helps.
4helpful
I have a GE universal remote and need the four digit codes.
Your Orion TV code is 0121,or 0135,or 0035. Your Orion code for DVD is 0394. Your Orion code for VCR is, 0256,or 0310. hope this was helpful
Lost the remote to our system
You can use an universal remote, but you will probably need to program the universal remote using the slow and complicate auto program feature, since the codes for many home theaters are not available.
Alternatively you can purchase an original replacement from one of the sellers below:
Replacement Remotes
1-800-Remotes
TV VCR DVD Stereo Remote
Best Replacement Remotes
Remote Controls Incorporated
123 Remotes Replacement Remote Controls
Toshia CT-90157 remote is not working!
Here is the product information for your remote: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C What is the correct model# for your set?
Toshiba ct-90157
What is the model# you own, for your TV along with yout satellite system box? MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
1helpful
2answers
Remote
Some more suggestions to see if your remote control has just lost it's programming is try unplugging your television and taking the batteries out of the remote control for atleast 5 minutes. If this doesn't work, or you've tried tvtek's advice up top and you still can't get your remote control to work, I would try ordering a original replacement remote control for your specific television. I would not recommend purchasing a universal remote, because half the time the problem with it not working could just be caused by it using the incorrect code. If you go to a site like http://www.remotecontrolscenter.com and look through their site for the exact model number of your television and purchase that remote control than you'll have a good idea if it's the remote or the television. Most likely you'll find it was the remote control!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
