Acer AL1914 19" LCD Monitor Logo
Posted on Jul 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an ACER 1914 LCD. How can I open to change capacitors
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jul 14, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366142
Points
33650
You remove the stand and all the screws, then use the flat blade screw driver to crack open the case, srating at the bottom center and work your way around. When you get the bottom side and the left and right side crack open just enough, lay the monitor face down on soft surface then lift up the back cover to release the top side edge.
Be real careful on the cable attached to the front bezel.
See example here; http://s807.photobucket.com/albums/yy352/budm/ACER/
Make sure to replace the caps in a set using low ESR type caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
2answers
Lcd acer al1917w dispay problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Repair Kit ACER AL1917W ILPI 031 LCD Monitor Capacitors Not the Entire...
Acer al 1914 nothing but rainbow-like vertical lines. Started after moving the screen.
The ribbon cable connections betwen the LCD panel and the logic board may have come loose, you should check that first, worst case will be the LCD panel, also inspect for any caps with domed tops while you are at it also. See the pcitures here:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
1helpful
When i sw itch on my pc my acer A1916W monitor shows the "acer" screen then it shows the screen for 1-2 sec and de n again shows the "acer screen and so on.......it goes on in this loop......tried...
Look for bad caps first.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Capacitors kit: <a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a> he can make you a set of caps for you.</span>
I have a lcd acer AL1916W IT WENT BLACK COMPLETELY
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1916W/
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
Look for bad DC filter caps and open winding on the inverter transformer.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
LCD Monitor Acer AL1717 shtting down problem
Aside from the capacitor and IC, there's a relay that you need to change. You need to locate that defective relay on the PCB and replace it.
It would be best to consult the manufacturer of the LCD and get the exact part number of it.
Have a great day!
Regards,
Firesnake09
My al 1914 acer monitor is getting fuzzy.
pls set ur pc speakers and and Ups or other adapters which are keeping at the near of ur monitor
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
