I have the same problem with the tv but i know is not thebfuse i j ust dont know hownto fix it
Hello my name is willie. I see this problem alot on these units at the shop. And from what you describe. THis might be the very common problem with the fl231 fuse. this is a very fine fuse that blows due to bad solder connections. If u can solder and get this very special fuse then this is a very easy simple repair. But the first question you can answer to determine if this is true. is that when you go into customer menu then setup do you have a convergence option in the menu if you do not it is definatley this fuse. if you do then it will be something else like convergence power board. let me know if it is and i will see if i can talk you through the repair.
