Have same problem. thought it was chorus so changed to SKY. still had buzzing... sounds like bees! so bought new ht tv... and still have buzzing... doing my head in! have tried unplugging all other electrical items to isolate problem and nothing works!!!
Hi
If picture and sound is Ok, and only this buzzing sound is heard from the back of the TV, It should be due to core soose of some ferrite cored transformers inside, especially to the power supply regulator board of the TV. Open the back cover of the TV and swtich it ON. Listeen very carefully which transfromer makes the buzzing noise. Just trouch and press the core of the transformer suspected with some non-cunductive material like glass rod, or a stick of dry wood. You can identify the transformer that makes noise by this way. After identifying the exact transformer; switch OFF the set, unplug it from mains socket, apply some "Super Glue" like fast boanding glue to the joint of core of that transformer. Allow sometime for the glue to set. This will solve the buzzing sound problem of your TV. OK
SOURCE: I have a proscan 42LA45H 42 in television that has
Need to locate the source of the noise first, open up the back and look for any sign of damages, power supply will be the first place to look.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Proscan+42LA45H+
