DELETED PICS FROM CAMERAS MEMORY CARD DID NOT HAVE ON PROTECT TOOK 20 MORE PICS. AFTER THE FACT THEN PUT ON PROTECT ALL NOW CAN NOT GET OUT OF PROTECT MODE
Remove the card and see if the pictures remain on the camera. If they do, then they are stored in camera memory. Make sure the memory lock on the card is in the proper position. Put the card back into your computer and delete the pictures. Then format the card, and try the card again. If the card is still locked, try a different memory card that has been formatted.
I don't have your camera, and don't know what kind of memory card you have, but many memory cards have a "lock" switch right on the card, easy to flick by accident.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
You should be able to read the card whether its protected or not. In fact I always protect the card before putting it into my computer so as to prevent the computer from doing anything to the card.
To delete all or just one of the pics on the memory card -- go to the play mode and use the Q Menu on the very bottom right -- you can select your choice from there.
In play you can also go to Menu and Protection and select if you want all or one photo protected.
Hope that helps! Took me a while to figure it out!
if your cam is using a sd card, the card could be locked, theres a little switch on the side of the card try using that and see wat happens. its tiny on one of the sides.
Memory card error is common problems in various sd cards and cf cards. I took a closer look at my little SD memory card. It has a sliding lock on it to protect data. Check to see if the card works when you slide that lock up or down. Read more about memory card: http://www.uflysoft.com/data-recovery-mac/memory-card-error.html
SAMSUNG S630
