SOURCE: Code to program universal remote
You can select between tv, AV, dvd using the buttons on the front (second from the left I think)
SOURCE: dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
SOURCE: Universa remote codes.
Definitely (Emerson) 720 for the Disney DT1350 TV...I'd love to have the code(s) for the DVD player, but I don't even know where to start. Thanks whoever tipped off mfr by Magnavox or Emerson.
SOURCE: replace remote for disney princes p1310atv tv?
Look on the back of the TV or in the back of the manual and you'll see the name of the company that manufactured and/or distributed the TV, or you may find a telephone number listed in the manual. You must contact the manufacturer to find a replacement remote for that TV. Universal remotes don't work because that set is actually made by a small company that doesn't communicate with universal remote makers.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
