NetGear Wireless-G Router WGR614 v9
I have set it up and it works fine with our Dell desktop and my MacBook. We cannot seem to get it to connect to a Dell laptop that is using a Belkin wireless card. The Belkin card is a wireless g card. It will not pick up the signal for our wi-fi.
It seems that your Internet download is fine but the issue is with the uploading. Try to switch of the router for few min. Remove all the cables out and press the Power button for 10 to 15 sec and replug the cables Check the internet connection. Check connecting to the face book or other web pages abd try uploading the small image first, If its not working .check the upload and download speed www.speedtest.net. and complaint to ISP to increase the Bandwidth Check the bu
for that you have to access your router.
connect your router to computer with ehternet cable.
then access it with following link. http://192.168.1.1
or http://192.168.0.1
type user as 'admin' and password as "admin" or blank or 'password'
then go to wireless security then you find WEP or WAP key there but it is in * or # format so you can't know it.
So you have to set new key so you can easily know it.
Then set new network key then save and restart the router then you can connect it with new key.
you put in the usb port then install the driver then you find it the wireless icon will came in the task bar right hand side in bottom then you right click on it then you got the option view viable networks click on it then you got the your ssid name just connect it then surf it
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
if you go to the netgear site, and get to the section for your model, you may want to update the firmware. this may solve most of the problems. you can also read what the latest firmware fixes. it should give info on the entire firmware history.
Are you connecting wired or wirelessly to the router?
If wired make sure the cables are properly connected and lights are lit on the router,
If wirelesly, make sure to enter the correct wireless settings on your laptop like ssid, channel and wireless security.
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
