It's possible this has two fuses. Check to see if either is blown and reset/replace. If not, then the "channel" (side) that won't work has been damaged and will be difficult to replace.
When the amplifier will turn on but not produce any sound that is usually an indication of either the high voltage power supply inside the amplifier is not working, or the amplifier IC or amplifier circuit is damaged. It is not something that can be repaired unless you have experience working on electronics.
either your amp is blown which it very well could be. or your just hooking something up wrong in the wiring. make sure ur battery wire and small blue amp wire are secure with a good ground
