Interestingly, your Kenmore Portable AC is manufactured by Delonghi. Occasionally, what you are experiencing happens when the humidity level is high and the air intake filter needs to be cleaned.
That also means that you will need to drain the tank, at least once.
You know where the drain plug is, so you can either carefully take it outside to drain or put a low sided container, capable of holding 1 1/2 quarts of water under the drain plug. If you drain it inside, turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to drain it.
Hope this helped you to solve the problem.
No, it's not necessary to take the unit apart. The filter holder and frame are on the back of the unit. Simply pull the frame off and your can remove the filter to clean it.
Your water is leaking because you're missing the drain plug. Mosey on down to Sears and order yourself a new plug otherwise the water catch drain is just gonna keep on leaking.
Thanks Gas Logs.
To clean the air filter, do I need to take it apart? or do I just take a vacuum to it?
Also, to drain the tank, do i need to take it apart or do I just tilt it and make sure all the water comes out?
Thanks.
