Seems to be keeping things cold. Last temp I took inside was 42 degrees... *sigh* I have it turned all the way up to 7 but it doesn't seem to be making a difference. The fridge part seems to be working okay, I haven't noticed a dip in temp there. I vacuumed out the back vent and cleaned the grill on the front near the floor like the suggestions already posted advised to do. Doesn't seem to have made a difference. And the noise is like something ramping up... goes on for about 4 seconds and then goes away. Sounds about every 2-10 mins. Help?? Am I at a point where it's gonna cost me a lot of money to fix?
SOURCE: Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
SOURCE: frost forms in freezer, blocking vents so temp in both freezer and fridge is warmer than normal
You have an issue with the defrost system, either the timer, thermostat or heating element. Probably the defrost timer refer to the manual to find it. If you don't have the manual check the makers web site for a parts breakdown. You should be able to put it into defrost manually by turning the knob and see if that helps. You may need to do this sevral times as it only stays in defrost for a little over twnety minutes and run cycle for 6,8 or ten hours. If the ice build up is heavy then twenty minutes may not do the trick thus the need for repated defrost cycles. If it does the trick replace the timer. If not check the thermostat and heater element.
SOURCE: The back wall of the freezer section ices up
tube caps could be bad drier needs to be replaced or low on freon
SOURCE: Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
What make and model?
