Cut the water off (just to keep from wasting water), remove the float and see if water has leaked into the float so that it became too heavy to rise with the water and turn the water off.
Everything else works because you can lift the float and shut off the water. The valve could be sticking in which case, replace or remove and lube with a bit plumber's silicon.
SOURCE: Dripping overflow from toilet cistern.
there is an adjustment screw ontop of the fill valve assembly. Tighten this down and the water level should stop at a lower level unless the internal mechanism has crusted up.
