My Seagate Barracuda 7200.10 400 GB used to work perfectly, but one day, it stopped working. I can turn it on and get it to run. I can hear it and feel it spinning and everything; but it won't show up anywhere on my Mac (2.5 GHz Intel Core i5 - 10.6.7 Snow Leopard)
Any drive will work - but you have to make sure that its physical configuration matches your pc and that you reformat the drive since the format used for dvr use is not compatible .
During the boot process you will see on the screen to press delete to enter setup Press and hold delete during the boot up process to enter BIOS you can load failsafe defaultsor load optimized defaults ,press escape then press f10 to save to cmos to restart then once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive hope this helps
Brother,it is a firmware problem for seagate drives,the 7200.10 has a typical problem of firmware,once it currupt,then it cannot be detcted by the BIOS or PC ,or showing 0GB or less capacity when connected,so you can use some useful tools such as HD Doctor for Seagate to repair it,this problem is very common but less tool can deal with it till now.
do a low level format with a software from hddgurudot com its free software. run it and choose this drive for low level format.it runs through windows it will make a new list of bad sectors and add it to the p list of the hard drive company settings
the first boot sector of the hard drive is corrupt so fdisk wont work please use software to repair the boot sectors zero and 63. usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Firmware updates and downgrades may only be obtained by contacting Seagate Support Directly.
If you have been referred to Seagate by a different vendor who has told you that you need a firmware update, please contact Seagate Support for more information and confirmation.
