Canon MultiPASS F80 All-In-One InkJet Printer Logo
Posted on Jul 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2 black running marks on length 0f sent fax, in middle of page.
  • akaylor1 Jul 12, 2011
    I did all that-cleaned the glass. I'm the sender of the fax. they received the papers with the marks on them. That has not helped.
  • akaylor1 Jul 13, 2011
    Yes,very helpful. Thanks abunch. The ADF platen glass has some white spects on the inside of it. Paper clear of all marks now. thanks again.
BONG BRON
Level 2:
  • Expert 344 Answers
  • Posted on Jul 12, 2011
BONG BRON
Expert
Level 2:
Answers
344
Questions
0
Helped
116912
Points
867
Good Day Akaylor1!
The fix to this problem is to clean the glass of the ADF platen glass or the flatbed scanner glass.
Use a lint clothe moistened with water or alcohol and wipe the dirt (mostly dried ink) on the surface of the glass.
If you have receive a fax and there is still the line, it is possible that the problem is on the sender. Let them know to clean the ADF platen glass of flatbed scanner glass of their fax machines.
That will fix it!
Please don't forget to rate my answer.
Thank you for asking Fixya.
  • BONG BRON
    BONG BRON Jul 12, 2011
    Good Day Akaylor!
    Perhaps, I should have been more specific.
    Clean the ADF platen glass. This is where the paper on the Automatic Document Feeder goes through for scanning. See the image below.
I am getting a white line down the entire page
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
1helpful
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
1helpful
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
When receiving a fax I get either big black plotches all over the page or thick black vertical lines running the whole length of the page to a point where I can no longer make out any of the information...
Try making a copy of something or printing a transmission report or journal from the "reports" menu. If the same problem is apparent on these printouts, then your drum unit or toner cartridge need to be replaced
4helpful
2answers
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Black border down the right side of the page, which blocks info
either you neede a new drum or this is problem in the fuser section. may be baf heater roller. try cleaning the grid on the drum cartridge with a soft bristel pauint brush good luck brother sr tech
Faxes only top of page center is blank
change your resolution from fine to super fine and make a copy to verify your fax machine"s scanner operation.
Lines Through Faxes
If WHITE LINE(S) appears clean the scanning unit...if BLACK LINE(S) clean the thermal unit.
1helpful
HORIZONTAL Lines on faxed/scanned pages.
I've seen this before. Since the printer portion is working fine that points to the scanner mechanism as the culprit. There are two things I have seen cause this. 1) If the line is a perfect rectangle all the way to the edge of the page then the light bar itself is dying and there isn't much you can do to save the unit. Send it in for warranty repair if you have the option. 2) If the line is more like a skid mark like you mentioned, then the paper that is being scanned is not pressing up fully against the light bar. Not enough light is bouncing off the page and the scanner can't read it well. This can also be caused by a roller not feeding correctly and then bunching up the paper a little bit. I would check the rollers for wear or something being off center. This can sometimes be caused if the machine has ran a high volume or thick paper. I would really think the cause would be one of these two since you are getting the marks at odd intervals, if the intervals were regular it could *possibly* be the drum but as I stated before, with the print function working right, I doubt it.
old marine
old marine
ZJ Limited
ZJ Limited
