Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
Posted on Sep 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a DDTV stb hooked up to a Sharp Aquos 42 inch of 2004. The image is very bad with all solid colours having a fake texture (repeated square pattern) and all the edges are smudged to the left in all rgb colours forming a kind of coloured shadow for everything especially the darker edges. To see issue please paste this in your browser http://tinypic.com/r/ok4eoz/7
Iulian Spuze
Level 2:
Habit-Forming:
New Friend:
  • Expert 81 Answers
  • Posted on Sep 11, 2017
Iulian Spuze
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
81
Questions
0
Helped
22237
Points
251
Capacitors (mostly on power supply circuit but also other cards) low capacity (due to old age and poor quality). Need specialized service.
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Mar 14, 2008
SOURCE: images go suddenly darker
Turn off the the OPC feature in the Menu. If that doesnt help, what youre seeing is most likely the Advanced Dynamic Contrast going to work. In layman's terms, it automatically adjusts the contrast depending on the video signal it is receiving. If you want to disable this, change the AV settings to "User" (button underneath the bottom door on the sharp remote)
A
Anonymous
  • Posted on Jul 09, 2008
SOURCE: SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
PanamanNE
  • 9 Answers
  • Posted on Jun 22, 2009
SOURCE: my sharp aquos picture has got
Sharp Aquos is a bit like saying Ford Estate . Without the model advice is a bit bland
There are know issues where the digital decoder can cause the main software to crash.
Although its not a DIY fix the updated software and a reset is often the cure fir this kind of issue,
If it is a software issue its the kind of thing we do over coffee break!
Chi Chu
  • 8457 Answers
  • Posted on Jan 15, 2010
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
Anonymous
  • 2777 Answers
  • Posted on Sep 29, 2010
SOURCE: Failed to receive broadcast E202 Sharp
What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs, do you have a DVD player attached, does that work? Did it used to work just fine with regular TV signal?
Thanks, let me know more and I can definitely help!
Tim
1helpful
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
5helpful
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
1helpful
2answers
2answers
I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
2answers
Line down the middle of my sharp aquos 42 inch
first make sure it does not come from the signal. If its really from the tv and look like a darker line it can come from the lcd control unit but most of the time its a dfective lcd panel
2answers
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
Sharp 42 lcd problem
I have a 10 month old Sharp Aquos 42 inch without sound. Has anybody encountere the same problem, and how do I fix it?
2answers
My Sharp Aquos
Burnt out pixel line. Usually the panel needs replacing
Image on screen of a Sharp Aquos 42"
Call P.T.S. Electronics at 1-800-844-7871 they can assist in correcting the problem. They will need the model #. Ask for technical support and they will tell you which module needs to be sent in to repair.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
