Fuji FinePix F460 Digital Camera Logo
Posted on Jul 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Forgot to set time and date when i turned camera on
Anonymous
Level 3:
President:
  • Master 287 Answers
  • Posted on Jul 12, 2011
Anonymous
Master
Level 3:
President:
Answers
287
Questions
Helped
209759
Points
1267
Hello and Welcome to FixYa!
If you have forgotten to set date and time then you can also set date and time after turned on the camera. to set date and time follow the given instructions:
  • Press the Menu button on the rear of the device, then choose Set with left or right button, Then go to Setup menu.
  • Select Option followed by time icon. This brings up the date display. The display blinks as it has not yet been set.
  • With the help of Right or left buttons select Year, Month, Day,Hour or Minute. Then press Menu/Ok button after the settings completed. Now every picture captured with the Fujifilm FinePix F460 will save the date and time to the pictures
I hope this solution helps you
For further assistance, I am here to help.
Thanks and Keep Visiting FixYa
  • Anonymous Jul 11, 2012
    How do you get th date and time to show on you photos after you have taken them and download to your computer? i really need this for work or i will need to buy a new camera.
    thanks,
  • Anonymous Jun 21, 2015
    I only set it to the year I got it but mine got stuck and would not set/advance to the next step to point & shoot. I had to plug it in to my computer and play with it with the frame-settings, and voile! It appeared to restore itself. Thanks God!
Is it possible to stamp date and time on pictures using a kodak cd82 camera?
To set the date and time on your camera, follow these steps:
Turn on the camera and set the language and date/time by following the instructions in the Extended User Manual.
Once you have set the date and time, you can turn on the Date Stamp feature by following the instructions in the User Manual . The date and time will be stamped on all pictures taken with this feature enabled.
KODAK CD82 - EXTENDED GUIDE EXTENDED USER MANUAL Pdf Download ' ManualsLib
KODAK EASYSHARE CD82 USER MANUAL Pdf Download ' ManualsLib
Have never set date on my camera. What do I need to do to accomplish this? Do I needsoft ware, any cords, etc? Tried to go by instructions on line but it didn't work. What am I missing? Thanks
Welcome to FixYa,
Hi I have here the steps on how you can update the date and time of your digital camera. You can chaged it if its your first time to set the date and then you also have here the steps if you want to changed it anytime you want.
Setting the date & time, first time
The Date and Time have been reset message appears the first time you turn on
the camera or if the batteries are removed for an extended time.
1 SET DATE & TIME is highlighted. Press the OK button.
(Select Cancel to set the date and time at a later time.)
2 Go to step 4 below, Setting the date & time, anytime.
1 Turn on the camera. Press the Menu button.
2 Press to highlight Setup Menu , then press the OK button.
3 Press to highlight Date & Time , then press the OK button.
4 Press to adjust the date and time. Press to advance to the next
setting.
5 When finished, press the OK button.
6 Press the Menu button to exit the menu.
Reminders:Depending on your computer operating system, Kodak EasyShare software may let your computer update the camera clock when you connect the camera.
I hope this steps will let you to resolved your issue.
Feel free to reply on this e-mail if this steps will work or won't work.
Thank you for using FixYa.
12helpful
2answers
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
3helpful
How can I reset the camera or modify the date & time of it? Regards
Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
6helpful
How do I turn off the date and time stamp on my canon powershot sx110?
The menu on the camera controls the date and time stamp. Turn on the menu i camera mode, there are three choices, Camera, Settings and customize. Time stamp should be in the middle menu. Look for time settings and turn it off. All pictures have time and date always. The time/date stamp just makes it visible in the image.
2answers
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
2helpful
2answers
Setting Date/Time on Polaroid a530
I contacted Polaroid help desk and they were clueless. They said there is no way to set the time after messing around with the camera for 10 minutes.
When you pull the photos off the camera it does record a date and time. I believe they forgot to add the option in the setup menu so you cannot get to it. I asked for them to send me a differant camera and the help desk rep laughed.
I guess thats what I get for buying a cheap camera.
2answers
Sony DSC-W150 power on keeps going to set date/time
The date and time settings are displayed after turning on the camera. Solution
sp.gif sp.gif It is normal for the camera to lose time and date settings if the internal battery is left uncharged for an extended period of time; some cameras will default to the time-setting screen when turned on if this happens. Follow the steps below to resolve this issue.
  1. Turn off the camera.
  2. Do one of the following:
    • Insert a fully-charged battery pack into the camera.
    • If the camera is supplied with an AC power adapter, plug the adapter into a working electrical outlet and then connect it to the camera.
  3. Allow the internal battery that retains the time and date information to charge for at least 90 minutes.
  4. After enough time has elapsed to sufficiently charge the internal battery, turn on the camera.
  5. Set the time and date.
  6. Turn off the camera for 30 seconds.
  7. Turn on the camera again.
  8. Check to see if the date and time have been saved.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Why does the date and time setting screen appear when I turn on the camera?
Turning on the camera while the date and time are not set or after the date and time settings have been cleared due to a total cut off of power (which occurs when batteries are dead and the camera is not being supplied power via AC adaptor) causes the date and time setting screen to appear on the monitor screen. When this happens, be sure to set the correct date and time before doing anything else.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
