SOURCE: sound works but no picture. black screen
I've had the same problem. Usually, if I turn the TV off and then back on again, it's fine.
SOURCE: I need to know the manufacturer of the digital lifestyles tv
the manufactures name is corian usa 800-278-6334 i had this problem and it turned out that u have to use LG codes.i also had to use lg codes to code direct tv sat box
SOURCE: my digital lifestyles 42 widescreen lcd hdtv won t power on
PLEASE NOTE IF YOU HAVE NO EXPERIENCE IN TV REPAIR SEEK OUT LOCAL TECHNITION OTHER WISE CHACK THESE THINGS BELOW.
1. check power supply
2. fuses
3. inverter.
Make sure you have no bad capcitors a bad capcitor is a leaking one or bulging at the top or sides if that is the case please replace them.
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Testimonial: "Thanks for this general insite. I'll seek a repair service and see what can be done."
SOURCE: my digital lifestyles 42 widescreen has power and
Unplug your television for fifteen minutes or so then plug it back and that should bring back the video.
SOURCE: i need the remote control
I have found nlaremotes.com to work really well for me. They are able to get you a remote that is just for your device (not a vague universal with limited functionality). The Digital Lifestyle codes seem to be a national secret.
