Http://office.microsoft.com/en-us/word-help/change-or-set-page-margins-HP001226492.aspx#BM2
try adjusting the margins in word to the following:
left 1 1/16 (Or decimal equivalent)
Right 7/8
Bottom 13/16
If the issue occurs in all print formats, then you may be able to set adjustments in the Print settings of the printer driver or make adjustments in the paper tray alignment for the left and right margin issue
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
