SOURCE: Little Giant Sump Pump Backup System Alarm Keeps Screeching
is there water? sensor maybe bad, or pump failing to cycle
SOURCE: my little giant water pump model 4mdsc has three
Sounds like you may have a 220V pump. So you need to confirm that this is a 110V pump and not a 220V pump. There should be a label or more info on line with any other info on the label. If you can confirm that this is a 110V pump, then put a standard plug on the cord - the green is ground and the other two can be wired to either blade of the plug. If you do have a 220V pump and you connect it to 110V anyway, the pump will perform poorly and will probably overheat and fail.
SOURCE: Our old sump pump went
The rs-5 switch is supposed to turn the pump on at 6 inches to 10 inches of water from the bottom of the switch and shut the pump off when the water gets to 1 inch to 4 inches from the bottom of the switch. Sometimes the pump takes a while to prime itself the first time it starts up. The noise at the end of the cycle is not unusual either.
Is water coming back to the pump causing the switch to close?
However, going on & off almost immediately is not right. Is the switch installed in a specific location that it is designed to fit on the pump?
It does sound like the switch is going back on at too low a water level.
Also, make sure it is not a rs-5LL for low level. Even this should not allow the pump to go on and off.
Gary
SOURCE: My Little Giant pump (554405) is connected to our
There could be gunk in the bottom....then the float does not work right and the pump will not pump either...
remove the pipes and/or hoses and then the screws that hold down the top....clean the inside really well and reassemble... that may work,,,, but it may already be burnt up...
if cleaning does not work the replace the pump...you should be able to buy a new one at a HVAC supply house or some place like HD or Lowes...they will be in the 50.00 or less range...
Testimonial: "Thanks for the suggestion. I cleaned out the basin, removed gunk and it seems to be fine now. Thanks again."
SOURCE: Little Giant 554455 VCMA-20ULS 230V
The float switch went bad... probably because of the water...you could replace it, but the parts are hard to get and with the time involved it will be easier and cheaper to replace it...
heatman101
Testimonial: "Clear, Consise and Fast, Great Job"
