JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
A
Anonymous Posted on Sep 05, 2005
Jvc 200u problem recording to vhs video tape, from camcorder
When I playback mini tape from cam to tv it is ok,{av3} but when I record to vhs tape in video recorder while tape is playing on tv, when completed and vhs tape is played back it starts of in black and white breifly then picture is distorted. The cam was purchased in usa and is used in uk would ntse system cause this or is there an adjustment I could make, thank you for any help.
  • sondramcisaa Apr 14, 2009
    its on safeguard and i dont know how to change it...the picture gets all distorted...
Anonymous
Level 3:
Master:
  • Master 473 Answers
  • Posted on Sep 05, 2005
Anonymous
Master
Level 3:
Master:
Answers
473
Questions
72
Helped
95515
Points
1373
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
2answers
Audio cuts out cyclical video playback unaffected
what model cam, if its mini dv and playback has audio cutting out then the cam that originally recorded the video had slightly off tracking and can only be fixed by playing back from the same cam that recorded it
Play back poor now Camcorder does not record
The head is dirty or bad - insert a brand new blank tape in the camcorder and perform a record through the entire tape without stopping the process until it finishes the record all the way through - this should clean the heads. Playback a pre-recorded tape. If it plays back ok then attempt an actual record. If unsuccessful, then the heads are bad.
6helpful
2answers
Problem lens cap
I had same problem with my gr-d73aa camcorder and jvc fixed it for free because it was manurefactures fault.
2helpful
Cannot record due to a black screen
OK, that means you can see clear picture in playback of old recorded tapes and camcorder just wont give you live view to record any more.
If its true then it is known problem/ failure of ccd imager in your JVC GR-D33 camcorder.
JVC will repair it free of cost, click JVC CCD Imager Advisory for details.
Thanks.
1helpful
I need a VHS adapter for the JVC Mini DV tapes
not available - the tapes are different widths for a start, and the two formats use different compression techniques. Adapters are available for VHS-C to VHS because the tape width and the recording format are the same.
SLOW DOWN PLAYBACK MODE
You cannot play SVHS tapes on a standard VHS machine. Your solution is to either:
1. Buy an SVHS Home unit (not a great idea)
2. Use regular VHSC tapes in your camcorder (these will playback fine in your existing home unit).
3. Hook your camcorder directly into your TV and use the camera as a playback device.
2answers
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Noise block doring playback of D-VHS tapes
* Do not record program in DVHS mode on an S-VHS cassette. Use of S-VHS cassettes will not allow for maximum performance and may result in head clogging. Use only D-VHS cassettes as recommended in the instruction manual on page 27. * Make sure that the DIGITAL 3-DNR lamp is ON when playing back a cassette recorded in D-VHS mode. If not press DIGITAL 3-DNR so that the DIGITAL 3-DNR indicator illuminates. * When block noise appears on the TV screen, clean the video heads with the DFC-2 D-VHS Head Cleaning Cassette (continue up to 3 minutes total). Please refrain from using any other head cleaning cassettes as drum damage may result.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
