JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
A
Anonymous Posted on Sep 05, 2005
Digital Resolution for 4x6
Have a JVC GR-DV500U digital camcorder that does stills at 1.33 megapixels. The camera does stills ranging from 1600*1200 down to 640*480; settings range from Fine to Standard/automatic and manual. I would like to know the best resolution for 4x6" prints and/or manual vs automatic. In advance, thanks.
Anonymous
Level 3:
Master:
  • Master 473 Answers
  • Posted on Sep 05, 2005
Anonymous
Master
Level 3:
Master:
Answers
473
Questions
72
Helped
95515
Points
1373
If you reckon 300 dpi on a printer printing 6X4 is a good enough resolution, then 6X300 = 1800 and 4X300 =1200 . 1800 x 1200 = 2.16 mega pixel then that is the camera you need.Probably your 1.3 megapixel shots won't be that good for printing.
Anonymous
Level 3:
Master:
Anonymous
Master
Level 3:
Master:
Answers
473
Questions
72
Helped
95515
Points
1373
You will need all the pixels the camera can produce so set the camera for 1600 x 1200 Fine. That should produce a good 4 x 6 print. I can't help with auto/manual as I do not know what they do on that camera.
1 Related Answer
Anonymous
  • 903 Answers
  • Posted on Sep 14, 2005
SOURCE: Digital Resolution for 4x6
3answers
I have a JVC Digital video camera model GR-DV500U I'm trying to connect to my computer with a dv cable. my computer handles the 6 pin but the 4 pin for the camcorder is to large for the connection. Can't...
I presume that you are using desk top computer, thus it has bigger connector. Solution, have find this connector so that one end fit to your cam and the other end fits to your PC. This connector have the same format(protocol) and easy to find in computer store. USB streaming is ok for this model for earlier windows OS, haven't try with windows 7 yet. hope it helps
2helpful
I'm using the JVC GR-DV500U model.When I turn on my videocam, the screen or even in the lens, is totally black, I wonder what's wrong.
Problem is this see the link just call JVC for free repairs for CCD Sensors u get streaks blackouts and discolored picture when CCD goes Bad no problem it is a known problem just call them in ur region they will arrange for free repairs dont worry if u are out of warranty and ur model is not on list this is valid on all models thru out the world with same problem and pls rate me FIXYA for help
http://www.jvc.co.uk/template.php?page=100102
Minimum illumination(low lux)-not with night shot on!
most sonys are 0-4 and i'd say yours is around 4-8-if 8mm cam will be much better in low light-mini dv would be worse
Can it use a digital card?
the card is used only for still photos. it can capture photos at a low resolution 640x480 - so not a substitute for a 3mp camera, but useful if you need to get some stills in for reference or on screen only use.
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
1helpful
3answers
Looking for a used/broken jvc GR-D290EKP camcorder
I have a jvc gr-d290ek digital camera which is not working due to cassette being stuck in the unit. Are you still looking for a used or broken camcorder of this kind?
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
