Sewing Machines Logo
Posted on Jul 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Viking 6370 sewing machine. I can not get the stitch selector to turn to select a new stitch. Actually the knob will turn but the outer dial doesnot turn and the stitch does not change. It sews a great straight stitch but the zigzag is graduated from wide to straight and then back to wide. I have the manual and it looks like it should do a regular zig zag. Any hints would be appreciated.
  • robbry Jul 22, 2011
    This only solved half my problem. The zig zag is working correctly but the stitch selector will not rotate
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Jul 12, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475444
Points
4013
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Testimonial: "That was the problem exactly. I am going to order a new cam gear and replace it. Thanks"
Model 6370. Why does it sew only in reverse when I select a pattern stitch?
Hi Sally,
I have worked on a few of the older Vikings and the pattern selector seems to get gummed up (something about the lubricant they used to keep the parts from rusting). Be careful with the plastic parts, they become very brittle with age and there is no easy way to get the machine apart because Viking hides the screws. There is a YouTube video of a tech working on the reversing problem, may not be the same model as yours but they are similar.
How do I repair the stitch changer on my Husqvarna viking
if the stitch selector is stiff, don't force it, some small parts that are no longer available could be damaged. take the machine to an authorized Viking repair center for evaluation.
Husqvarna 6430 stitch selector knob won't turn
This repair will need to be done by a Viking dealer since it will require the covers to be removed. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Stitch selector knob turns but doesnt change stitch from a straight stitch on kenmore ultra stitch eight, model 13453
when a part on the sewing machine does not respond like it's suppose to ,,then it would be a good idea to have the sewing machine checked
2helpful
3answers
Viking Husqvarna Model 6020 stitch selector will not turn.
My stitch selector keeps turning around and around
You will need to take the machine in for service.
3helpful
2answers
4helpful
I just bought a used Husqvarna 2000 sl without a manual.
If you have on old Husqvarna 2000 from the 1970's, then the knobs are as follows:
Top front left: Pattern Selector
Top right: Stitch width
Lower: Stitch length and buttonhole (when turned to 0 and pulled out)
Extreme left: Upper tension
Side left: Presser foot pressure
1helpful
Cannot not see the stitch selected on screen
Look in your manual to find out where on your machine the dimmer is.
2helpful
Reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
