Question about Vtech Cordless 6041 Phone
How to change the amount of rings before the voicemail pick up
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
The 6041 isn't an answering machine. If you have an answering machine connected to your phone, refer to its documentation. If you subscribe to a voicemail service offered by your telephone company, contact them for information.
If you need further assistance, please feel free to repost your question, but make sure you specify whatever answering machine/voicemail system you're using.
Posted on Sep 16, 2011
SOURCE:
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
How do I change the number of rings on this phone?
The KX-TG2313 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count, refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 15, 2014 | Panasonic KX-TG2313 Cordless Phone
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
Number of rings before voicemail picks up
What make and model phone/voicemail?
Feb 19, 2013 | Lands Phones
How do you change the amount of rings on the uniden dect1363 6.0 GHz
The Uniden DECT 1363 isn't an answering machine. It will continue to ring until someone picks up, a separate answering machine or voicemail system picks up, or the caller hangs up. You need to refer to the documentation for your answering machine or voicemail system.
If you require further assistance, please repost your question specifying the make and model of your answering machine or voicemail system.
Sep 18, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 | Cell Phones
Trying to change number of rings before voicemail picks up
This is done in station administration. F config side of the system. Do you have access to system programming?
Jul 21, 2009 | NorStar T7316 Corded Phone
Changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Feb 14, 2008 | Uniden Cordless Phone
Answering machine not working
change how many rings your voicemail picks up in or cancel it.
set your answering machine to less rings than your voicemail.
Aug 29, 2007 | GE Telephone pr521w
Vtech Cordless 6041 Phone Logo
60 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
