Question about Goldstar R5050 Air Conditioner
It has been blowing warm air. It will blow cold air for about 5 minutes and then warm air all over agian.
  • Goldstar Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble
- Review the Possibilities
heatman101
Posted on Jul 12, 2011
SOURCE:
My 2005 chevy avalanche only blows cold air until i drive then when I stop cold air Agian
One of two things has happened. Either your coolant has gotten really low (easy enough to check) or you heater core is starting to plug up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 14, 2012 | 2004 Chevrolet Avalanche
AC blows warm air whil idle or at first start
U could be run on eco a/c where the engine is using the power until it has extra to spare. Warm at start could be simlarly that there is now cold air yet and has to "make" cold air to distribute when ready. See if u can find a setting for reg use. cheers, ps eco saves dollars/euros.
Sep 05, 2012 | 2005 Audi A4
LG LP0711WNR blows cold air for a few minutes, then starts blowing warm air. It will start blowing cold air again if I wait several minutes. Or if I turn it off and wait a few minutes it will blow c
I just experienced this problem myself. What helped me was cleaning out the lint trap. My guess is that the until sucks in air through there, then conditions it. Blows the cold air out the top, and hot air out the tube. When it can't suck a decent amount of air in, the condenser can only condense so much of that limited amount of air. When it runs out, the unit just runs the fan until enough air has been condensed.
My lint trap was filthy, hadnt Bern cleaned in years. Soon as I popped it off, the unit started belching out cold air nonstop. Clean your lint traps! Don't make my mistake!
Jul 09, 2012 | LG LP0711WNR Portable Air Conditioner
Air conditioner only cools sometimes
Your convergence is off. See the owners manual or call tech support to walk you through a convergence.
May 06, 2010 | Haier HPAC9M Air Conditioner
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
MY 1998 FOR TARUS HEATER WILL NOT WORK.WAS DRIVING
It is most probably the problem with blend door or blend door actuator. But just in case I would suggest to follow the entire procedure:
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
Heater not working
Sharp 10000 BTU 38db portable air conditioner blows cold air for 2 minutes then blows warm air for 5 minutes then turns off for 20 minutes then repeats this process. How can I fix this problem to blowing...
sounds like the unit has a low charge and is cutting out on a low press safety. This is more then likey not something you can fit yourself most of this units are not really serviceable with out cutting the lines open and adding a valve. If the unit is still somewhat new you can try for a warranty repair, if not you are better off to replace it.
Aug 30, 2009 | Heating & Cooling
Lumina APV air conditioning, randomly
it sounds like a vacume hose is colapsing , there is also a vacume booster it looks like a round black ball and can be failing cheap fix get from junk yard just about $5
Jul 12, 2008 | 1995 Chevrolet Lumina Apv
Goldstar R5050 Air Conditioner Logo
319 people viewed this question
Top Goldstar Heating & Cooling Experts
John Tripp
John Tripp
Sumeet Sodhi
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
