7752V Replacement Transmitter Supercode Remote for 5901 Responder LC3 Logo
Posted on Jul 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just received a brand new viper 7752v remote and it will not power on even when plugged into the charger. I have tried to press the function key several times to reset it and nothing. Any Suggestions?
  • 1 more comment
  • Anonymous Dec 02, 2012
    I have the same problem!!! I already plug and unplugged several times without luck
    My alarm is also 7752v is dead and wont turn on
  • Driven Audio Ltd
    Driven Audio Ltd Dec 22, 2013
    Use a high amp charger (like the wall charger it came with, not a weak USB port). Press and hold the F button on the side, then plug it in and wait a few seconds then release. The remote should "wake up" and start charging.
Larry Spears
Level 3:
  • Viper Master 625 Answers
  • Posted on Jul 17, 2011
Larry Spears
Viper Master
Level 3:
Answers
625
Questions
0
Helped
377831
Points
1510
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
  • 1 more comment
  • Anonymous Sep 23, 2012
    Woah... holy cow this actually WORKED! My remote was dead for 2 years and I was able to fork $100 on eBay but this worked and its charging!!!! Thnx!
    I have the same problem i plug and unplugged more that 20 times but didnt work..
  • Anonymous Mar 15, 2013
    With lithium battery there is a low cut off voltage. If you dont charge your battery and let it sit it will lose voltage due to the chemistry. If the battery goes past this low voltage cutoff it takes a while to charge it if at all possible. The battery will die if it get way to hot(ie left in a car on a hot summer day), charged x amount of times( some say 1000 times) or overcharged or discharged past the point of no return. I sell new batteries on ebay. Once you install a new battery it takes a minute for the remote to power up. Then try to charge it. If the charge doesnt come up disconnect the battery and try cleaning the usb connector with contact cleaner or alcohol. Hopefully this helps.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 27, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5327
Points
0
It took several minuets for my new remote to register anything. I just assumed they came completely dead and it takes a while to get to the point where it will function.
My sst 7752v viper remote will not unlock my doors, it just beeps. I cant get into my truck without my remote... please help
how old is the remote is a question to consider. the batteries might just be too low to send a strong enough signal for the truck's transponder to receive. does the remote need to be coded to the truck if not more than likely its weak batteries. the LCD display doesn't need much power to light up, but the remote does to send the signal.
I need a charger for 7752v remote
you can charge it from your computer if you have a mini usb cable like one from a camera would work. Also if you have an old cell phone charger that has the mini usb connector on the end will work. The motorola driod x charger would be a perfect match. If you need to replace the battery because the remote will not turn on any more I replace the batteries on ebay search viper 7752 remote battery service. Hopefully this helps.
My Viper remote won't turn on or charge.
The battery is probably dead. There is a guy on ebay that is replacing them. He fixed mine and it works great. The batteries dont last forever and you cannot just buy them they are a special type, also viper suggests you buy a new remote for $299 because they do not replace the batteries... how convenient. Hopefully that helps.
Remote 7752v dead wont start
I replace the batteries in the remotes search ebay viper 7752 remote battery replacement.
Dec 02, 2012 • Viper 7752V
1helpful
2answers
Need viper 7752v owners manual
The 7752V remote is compatible with five Viper systems. The owners manuals for each respective system can be downloaded via the following links:
5904
4704
5501
5901
5704
1helpful
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
25helpful
3answers
Will not charge
I have the viper rpn 7752v remote. I was away for a month and the remote completely died. I plugged it into the usb and nothing would happen. I called the installer and he told me a savvy trick. After plugging it into the usb, press the function button. Repeat this several times before it actually turns on. Repeated attempts eventually worked. He said even the manufacture doesn't know why this works. If you still need help you can email me and I'll refer you to a good installer. [email protected]. Tony Madan
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
