Radio Communications Logo
Posted on Aug 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Uniden hr2510 10 meter lights up, won't transmit or receive
Patrick Patterson
Level 2:
New Friend:
  • Expert 109 Answers
  • Posted on Aug 27, 2008
Patrick Patterson
Expert
Level 2:
New Friend:
Answers
109
Questions
Helped
39428
Points
115
Have you tried a different michrophone. If you have then the radio will have either a cold solder joint on the main board or a transister has gone bad. The unit will require service at a local radio shop or send to Uniden Service center.
Pat N5SLI
What should i look for if my uniden presiden jackson cb back light on meter lights up but has no led on channel display, and no transmit or no receive
Check to make you are not on PA.Make sure the radio is on. there are diodes controling the lighting for the display.
A uniden Madison base station with digital clock that transmits and receives but has no modulation
could be your final , could be the modulation transformer, could be your coax, could be your mic. Hows the SWR . under a 2.0 I hope.the smaller the # the better you get out .
1helpful
Why no modulation in transmit mode?
Without seeing it I would guess (and it's only a guess) that maybe you have a broken microphone wire. If it's a factory mic the most common place for it to break is right up from the mic plug. Factory cords are not flexible, their really stiff. We could really use some more information. Mike
What's up I have a uniden Washington no sound out of the speaker but it is receiving you can tell by the s meter moving.?
do you have the volume turned up? Squelch turned all the way left and RF gain all the way right. If you still don't hear anything check to see if this model has a dynamic squelch .If it does turn it off.
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
1helpful
Uniden pc78elite antenna light
What kind of antenna is it? Have you checked your standing wave? To do this process you will need a field strenth or a SWR meter to do it,would be cheaper to have it checked at Radio Shack or you can buy one,and do it yourself. Some radio antenna light come on when transmitting,....hope this helps....
Pc78elite won t transmit but receive is ok
Have the SWR's ever been checked on this radio when it was installed? where they over 2 or higher?
Most likely the final transmit transistor is bad from too high of an SWR.
Top Midland Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
