Hitachi DZ-GX20A DVD Camcorder Logo
A
Anonymous Posted on Sep 05, 2005
Video playback is not smooth while playing via USB 1.1
Why is my video playback not smooth when playing via a USB1.1 connection?
Anonymous
Level 3:
Master:
  • Master 473 Answers
  • Posted on Sep 05, 2005
Anonymous
Master
Level 3:
Master:
Answers
473
Questions
72
Helped
95406
Points
1373
USB1.1 port can generally handle transfer speeds approaching 5.5Mbps between PC and DVD Camcorder. Smooth playback of movies requires 5.5Mbps speeds or above. If the PC you are using has some compatibility issues with the USB driver software, the USB port may drop to speeds below 5.5Mbps causing short pauses during video playback. It is recommended to copy the movie file from the DVD Camcorder to the hard disc drive (HDD) on your PC, then playback the movie from the hard drive.
1helpful
MY SONY BRAVIA MODEL NO. KLV-32BX300 ARE NOT PLAYED VIDEOS IN FLASH DRIVE WHICH KIND OF VIDEOS ARE PLAY IN THIS MODEL PLEASE HELP ME FOR THIS PROBLEM
"Bravia Engine 3; built-in FM radio and clock; onboard JPEG, MP3, MPEG-1 and MPEG-2 playback via USB; 1080p24 input-ready; Bravia Sync (HDMI-CEC); dual HDMI terminals."
I have the above model camcorder ,the playback on my laptop with windows vista is terribly poor jumping all the time/distorted with jvc software provided or on windows media player it plays but audio is...
Are you playing the video directly form the hard disk in the camcorder or are you transferring the file to the laptop first? Reading high volumes of data via USB is slow and the PC may not be able to read the data fast enough from the camcorder. Try copying the video to the laptop first, then play it back.
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or...
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Need to know how to transfer video from digital camera to computer
To transfer camcorder video to computer, you need the following:- 1. Firewire cable (it looks similar to the USB cable, but has very high speed capability)
2. Appropriate software/application.
If a firewire cable did not come with your camcorder then see that purchase one right away, ‘cause you will always need it for this purpose. Then you should have a video editing software like Adobe Premiere or Ulead installed on your system. Adobe Premiere is recommended for its speed.
Once you have these in place, all you need do is connect the camcorder to your computer via firewire, have your video editing application/program open, and simply playback. You will observe that the playback on the camcorder is at the same time being shown on the computer screen within the application. While the mini DV tape is playing back click on capture on the video editing application you are doing the playback from, i.e. Adobe Premiere, Ulead etc.
1helpful
USB driver 2
Can you be more precise? You don't need USB driver for this PC...
7helpful
Audio drivers needed for my pc. plz help.
Sound card driver for
Realtek AC97 Audio CODECs Driver v4.06 Windows 98SE/ME/2000/XP/2003(x32/x64)
http://www.opendrivers.com/driver/286655/realtek-ac97-audio-codecs-driver-v4.06-windows-98se-me-2000-xp-2003(x32-x64)-free-download.html
FLIP: playback is frame by frame (jumpy) and... voice not in sync
i have a mino that only started doing this when it was upgraded via the usb. any help?
Choppy Video Playback
it's probably the codec you're using. divx works nicely.
2answers
Playback is not smooth.
For best results I recommend downloading the video files to PC first and then playing them.
Top Hitachi Video Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
