Question about Canon DR-9080C Path-Through Scanner
"Skip Blank Page" but still inserts one
Canon 9080C with settings at "Skip Blank Page" and black pixels increased to .5% and we still experience blank pages occasionally. If we wait, give them a few minutes and come back to the scan it will be fine. Help us to figure out how to correct the unwanted blank pages.
I have two of these scanners the only way that i have found round this is to scan the pages duplex then remove the unwanted afterwards!
Posted on Oct 14, 2008
SOURCE:
Missing pages with print only on the bottom of page
This may be because you have selected to have the scanner skip blank pages in the software, and it is thinking that the page is blank. Try deselecting that option and see what happens...
Kris
Jun 17, 2014 | Canon DR-9080C Path-Through Scanner
Scanner adding blank pages
Driver is probably set for "Skip Blank Page". Adjust "ratio of Black" slider if it is to reduce falsely detected blank pages.
Apr 24, 2014 | Canon DR9050C
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
Blank backsides not deleted
Hi Keegan,
Please check the blank page skip adjustment in the settings option. You may also refer to the TWAIN driver and ScandAll Pro application(if using) help guide for details.
Thanks,
ScanCare
Apr 04, 2012 | Fujitsu fi-5900C Pass-Through Scanner
How to increase pixels on my Canon SD1100IS
Press the FUNC/SET button. Use cursor-up/down to move to the lower-left corner. Use cursor-left/right to change the setting. The "L" setting gives you the most pixels (8 megapixels).
Full details are in the "Changing the Recording Pixels" section of the manual (page 68 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/5/0300000755/01/PSSD1100IS_IXUS80IS_CUG_EN.pdf
Sep 15, 2011 | Canon PowerShot SD1100 IS Digital Camera
I can't scan different document sizes (A3 and A4) in one batch with the Canon 9080C.
IF you are using CapturePerfect 3. version, you can select "Auto detection" for page size, and under 'more' select 'image size' instead of guide plate. Also you may have to select option '1' under user code U10 in case you want to scan pages over 17 inches long. (Press Newfile and Countonly simultaneously, press 'newfile' till you get U10, press 'countonly' and select 1. This will enable scanning upto 1 meter long).
CP3 has "Skip Blank page option", this helps you to automatically delete blank pages on the back side and scan only those with data.
S. Mohan, Chennai, India
Dec 03, 2010 | Canon DR-9080C Path-Through Scanner
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
"Skip Blank Page" Set to 0.1% Yet still skips pages with footers and headers
We have the same problem where I work. We use a black texta and draw a line down the middle of the page. This gives the scanner a point to pick up apart from the minimal text at the top. However, this will only work if you are happy to have a line on your scanned document!
Apr 09, 2008 | Canon DR-9080C Path-Through Scanner
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon DR-9080C Path-Through Scanner Logo
482 people viewed this question
Clive
Clive
old marine
old marine
Ekse
